EM TuningVolks Autos
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    No sound from pc speakers??
    I dont know what has happened but i dont get any sound when watching youtube or the start up noise or that noise you usually get when you empty your recycle bin but i can hear sound when playing stuff through windows media player so im guessing its a setting or something,anyone know what i can do???
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    My Computer, Control Panel, Sound and Audio Devices,....under Sounds
    and check there
    You can slo check check under Audio for the input devices.
    rich32uk's Avatar
    Kent
    109
    Not sure if you've sorted this by I've been having the same problems. It seems that one of the versions of macromedia flash deletes a file called wavemapper from the windows registry; I understand that this manages all your internet sounds.
    All you need to do is to open registry editor by going to Start menu, Run, type regedit and then Enter. After that, in the registry editor, walk yourself through the tree in the left hand pane, untill you reach
    My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Win dows NT\CurrentVersion\Drivers32
    Then on the right pane, right click and click on New, select String value, enter "wavemapper" (without quotes of course), ENTER, then right click on the new file "wavemapper", press modify and type "msacm32.drv" in the box that says value data and press enter.
    No need to reboot, it should work straight away.
    I got this information from the adobe forum. There seems to be loads of different solutions but the one above worked for me.
    http://www.adobe.com/cfusion/webforu...read=y#4517539
    rich32uk's Avatar
    Kent
    109
    I am assuming that your on XP and not Vista? I can't vouch whether this works for the latter
    james0808's Avatar
    Mar 2006
    Nottingham
    3,542
    Thanks alot rich32uk.
    I just reran my windows disc and they worked again.
