Monster MotorsportVolks Autos
Results 1 to 15 of 15
Thread: Sky+ & 40' LCD
    Jan 2007
    Renfrewshire
    118
    Sky+ & 40' LCD
    I'm having problems with my sony KDV-40V3000 and connecting my sky+ box.
    The picture quality in Freeview is better than sky.
    In sky it is soft/blurry/cloudy.
    I have upgraded my scart to a Monster 3 scart to scart which helped with the colours but still aint helped.
    I have (for day's) adjusted the picture settings for both freeview and sky, made them both the same- still no luck!
    The freeview is built in does this matter???
    Thanks Ross
    A4 Avant 2.0tfsi S-Line Quattro 2010, Misano Red, thinking about bluefin when i have the cash
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    Make sure your Sky box output is set to RGB
    Check your signal strength and quality too, shouldnt make a difference though
    Your built in freeview will probably be a better picture because it is built in and doesnt have to be connected via scart etc..
    How long is the cable you are using? Are you sure its the picture quality and not that your too close to the screen even the best screens look dodgey when your up close to them!
    Ash
    2001 Audi S3 l MTM Remap l 252.7bhp 432.4Nm l Forge 007P l ECS Porsche Stage 2v2 Front Brake Set-up l ECS Stage 1 Rear Brake Set-up l 18" RS4 Alloy Wheels
    Jan 2007
    Renfrewshire
    118
    Quote Originally Posted by ash_s3
    Ash
    Thanks for the reply.
    Yeah its on RGB, and the cable is only 1m which is the minimum it can be.
    I'm not sitting too close, which is good advice when anyone is in the shops looking because you are usually too close!
    Anyone anymore ideas or does this happen to other people too?
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    Even though you have selected RGB on your Sky box it may not have switched over you need to check the input on your TV too. Our Sky box seems to switch from RGB to video even though the display indicates RGB, it then has to be forced back to RGB
    99 S3 Absolute red
    Forever going forward!
    Dec 2007
    Bridgend, South Wales.
    20
    Hey,
    Anyone know how to put sky+ box to RGB?
    The issues described above sound like whats happening to the in-laws, maybe this can help them!
    Cheers, graham.
    Nilz's Avatar
    Defo worth the wait :)
    Apr 2006
    10,092
    Press services on the remote, then 4(pic settings), then change video output to RGB, make sure you then go down to save new settings, press select on that and it should be set for you...
    Hope that helps.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    LCD's, Sony in particular in my experience, give a shocking picture when connected by old-hat scart.
    It is an analogue connection, after all.
    You should invest in a HD box, even if you don't want to pay the HD subscription.
    You can then conenct via HDMI (proper digital connection) and you won't believe the difference, even on SD channels.
    If you already have SKY+, you can self-install HD.
    Just a straight swap, then phone SKY to match the box and card.
    Like I said, you don't even have to take the HD channels, if you don't want to.
    Oh, you get double the recording capcity of SKY+ too.
    Best 199 I ever spent.
    My SD HDMI pictures are superb.
    HD is better again, but that's whole different argument!
    BTW, don't spend extra on a fancy HDMI cable.
    Waste of money.
    Being a digital connection, the little '0' and '1' s either get through, or they don't!
    So the one that comes with the HD box is perfectly fine.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Nilz's Avatar
    Apr 2006
    10,092
    Bowfer, so are you saying that you have a Sky HD box from Sky, but you are not paying the £10 per month, I was under the impression that if you had one of those boxes you had to subscribe to the HD channels???
    Also how many HD inputs/outputs does the sky HD box have???
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by nilz18t
    Bowfer, so are you saying that you have a Sky HD box from Sky, but you are not paying the 10 per month, I was under the impression that if you had one of those boxes you had to subscribe to the HD channels???
    I do subscribe to the HD channels, but you don't have to.
    Many people, including me, buy their own HD boxes off the net and plug them in themselves.
    They then benefit from the HDMI connection, which greatly improves all channel picture quality, and superior recording capacity.
    They can always add the HD subscription later, when more HD channels appear.
    I could live without the HD channels, but I couldn't live without the HD box.
    BTW, the HD box has one HDMI socket.
    Jan 2007
    Renfrewshire
    118
    Thanks for the reply's
    Bowfer i like that idea, were did you buy your HD box from, sky are wanting between 250 and 300.
    Does it carry a warranty etc
    Dec 2007
    166
    Interesting stuff, I've just set my Sky + box settings to RGB and yes, it made quite a difference. Thanks for the advice.
    Sorry to change the subject, but if I bought a Sky HD box to replace my current Sky + box, does anyone know if I would be able to use my Sky + box elsewhere in the house?
    Thanks in advance.
    mitch78's Avatar
    Mar 2007
    noun: a particular place or position
    2,723
    Ex 8L S3 driver
    also A3, 320, Golf, Clio, Astra, Focus, Mondeo, Laguna, Escort, Calibra, 220, others and now back to a Focus...
    Nilz's Avatar
    Apr 2006
    10,092
    Again going off topic for which I apologise, but do the USBs on the front of the Sky+ box do anytyhing, i mean, can i plug a memory stick in and copy from my planner to it???
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Quote Originally Posted by rosscotdi
    I got mine from a company called Pennine Plus, for 199.
    The usual 12 months warranty came with it.
    The first box I got was noisy, which should have meant boxing it up and sending it back to Pennine?
    I decided to phone SKY direct and 'play dumb' though.
    They just sent an engineer out with a new one, just as if I 'd bought it from them as normal.
    Just goes to show what an incompetent shower they are, but I was delighted.
    Oct 2006
    246
    Like Bowfer I ditched my Sky+ box and bought a new Sky HD box from Ebay for my Samsung HD Tv. Installing the HD box and pairing the viewing card is a simple 10 minute job.
    The picture using the digital HDMi lead/connection is far superior than the picture I got from my old Sky+ box via the analogue scart lead.
    I don't subscribe to Sky HD anymore as I found the content to be a bit poor for an extra 120 a year. BBC and CH4 HD are free to view tho.
    If you've paid all that money for a good Tv, you may as well get the best picture possible on it!
