Results 1 to 18 of 18
Thread: 360 problem
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Angry 360 problem
    Anyone not able to turn on there 360.
    Mine is just flashing a red cirlce with no signal...
    2013 AUDI A3 SB S-LINE : 2.0 TDIQ 184 : GLACIER WHITE :
    : S-TRONIC : COMFORT PACK : SD SAT NAV : FOLDING MIRRORS : HEATED SEATS: RIGID BOOT LINER :
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    is it 3 red lights ?
    common problem this is on 360s
    MS will replace your machine with a new one
    ~ ~ ~2003 Audi S3 BAM ~ Ming Blue ~ 18" BBS Alloys ~ Heated Black Leather ~ Forge DV ~ RNS-E ~ denison ipod link~ parrot mk6100 bluetooth ~ ~ ~
    Still need Remap
    2007 Audi S3 8L
    2005 Audi A3 1.6 sport grey with climate control
    2003 Audi A3 1.6 sport black without climate contol
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Thanks, just dropped them an email.
    DIPS_A4's Avatar
    SEAT LEON CUPRA R (225)
    Mar 2006
    Leicester
    566
    I had the same problem when i fitted a nyko rear intercooler on mine, have u fitted 1 on yours?
    Oct 2006
    246
    Quote Originally Posted by DIPS_A4
    I was planning on fitting a cooler to my 360 as its housed in a TV cabinet. Did the fault clear when you removed the cooler????
    My local games shop has a cooler fitted to the shop demo 360 which is on all day, 7 days a week. Its been running with one for months ...... I asked about one and they said that their shop machine never overheats or crashes with the cooler fitted.
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    dont buy the cheap cooler of ebay, the cooler does work very well and stops the machine from over heating,
    ill see if i can find you a link
    Still need Remap
    2007 Audi S3 8L
    rickparmar's Avatar
    va va voom
    May 2004
    Leicester
    2,269
    Still need Remap
    2007 Audi S3 8L
    Jul 2005
    2,488
    are 360's really this rubbish with cooling?
    Oct 2006
    246
    Quote Originally Posted by madvw
    No ......... BUT ..........
    Never had any issues at all when it was on one of those fancy glass stands that come with modern TV's even after hours of use. The Xbox kicks out a hell of alot of heat compared to any other games console Iv'e owned.
    Since getting a wall hung LCD TV and putting the Sky box and 360 in a cabinet I sometimes get a disc error message after a few hours of use. The cabinet has holes in the back but the ambient temperature inside is noticabley quite warm. Turning the 360 off for a few moments before restarting solves the problem and works fine again for a few more hours.
    The extra fans help prevent the overheating issue for 360's in cabinets according to 360 forums.
    DIPS_A4's Avatar
    Mar 2006
    Leicester
    566
    Quote Originally Posted by coupe-se
    Its runs ok now just make sure the connection is proper on other wise it will show errors its the same link which rickparmer has put up the nyko 1. does get noise but works for hours of hasell free gaming specially when you are live it can get very addicting.
    http://www.play.com/Games/Xbox360/4-...0/Product.html
    Oct 2006
    246
    Cheers mate .......... just ordered one, can't go wrong at that price!!
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Just got mine back, minus £82.
    Have logged the complaint at Watchdog.
    http://www.bbc.co.uk/consumer/tv_and...20070213.shtml
    Audi S3 (2000)
    Mar 2007
    303
    doesnt over heat if well vented.
    the nyko was reported to cause a fire hazzard, burning at the power socked.
    'circle of death' read lighs is caused when the main board heats and expands causing the board to pop, this makes the CPU pop out of its slot slightly.
    if its out of warrenty is worth opening and removing the heat sink and pushing the CPU back in.
    Nov 2007
    I work in tech support
    20
    my new one seems not to get that hot certainly kicks out a lot less heat than my old shuttle box did - and a lot less than my new quad core pc i'me building but it is in a case with 6 fans the antec 900.
    I had head that the newer ones are fabed using a smaller process which will inherently run cooler.
    Unlike a saxophone, a lawnmower can be tuned
    Audi Nationwide
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    I had the same prob with mine , microsoft replaced it free of charge , that part now has a 3 year extended warranty , new one been fine, they replaced the machine within a week
    TDI-line's Avatar
    Uber Post Whore
    Oct 2004
    Peterborough
    8,883
    Quote Originally Posted by TDI-line
    Just got mine back, minus 82.
    A good few months later, MS refunded the money. Nice result.
    S3quatt's Avatar
    Flat Oot like a ducks Foot
    Jan 2007
    Sunny Scotland
    564
    Have you read the reviews? loads of people who have used this reckon it caused an overheat!!
    ...... Waiting Paitently...
    Oct 2006
    246
    Well ........ 10 months on from my previous post on this thread and my Nyko Cooler is still doing its stuff and my 360 is 100% trouble free. Even after hours of non stop use in its cabinet ....... no problems or errors.
    My console seems to be one of the few original consoles not to suffer from the dreaded red rings and works perfectly.
    The important thing with the Nyko coolers is to ensure they are clipped firmly to the 360 and that the supply plug is inserted firmly. If the plug is slightly loose the low voltage/high current that passes through it causes heat damage. Same with any electrical connector, a loose connection with cause overheating and heat damage will occur.
