AH FabricationsVolks Autos
Thread: DVD unlocking
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    DVD unlocking
    Hey people my dad has a Sony DVP-S735D DVD player which I doubt is multi regional so i was wondering if anyone knows how to unlock it.
    Its just I was going to buy a couple of DVD's for his christmas but they are region 1(US).
    Cheers.
    A4 1.8T Quattro
    nick1973's Avatar
    Nov 2006
    97
    dvd unlock soory for long thread might work
    Sony DAV-S300
    Put your player into Standby" Mode and enter one of the following commands if necessary, : Remote control command Function : [0] [RETURN] Default Default region code on the player : [1] [RETURN] Region 1 : [2] [RETURN] Region 2 : [3] [RETURN] Region 3 : [4] [RETURN] Region 4 : [5] [RETURN] Region 5 : [6] [RETURN] Region 6 : [P. MODE] [RETURN] Only play DVDs with the selected region; auto switching OFF : [AUDIO] [RETURN] Default Auto switching ON : [ANGLE] [RETURN] Enable video interference impulses (Macrovision ON) : [SUBTITLE] [RETURN] Default Disable video interference impulses (Macrovision OFF) : [PREV] [RETURN] Enable user operation prohibitions* and access restrictions : [NEXT] [RETURN] Default Disable user operation prohibitions* and access restrictions.
    Sony DVP-C660, Sony DVP-C670D, Sony DVP-CX860
    Switch off, press 5,5,5, then menu, and then hold down 3 for 3 seconds.
    Or
    While your system is turned OFF press: the TITLE button then, the CLEAR button then, the POWER button. Select the region
    Sony DVP-CX860
    Open the drive tray. Enter 9,8,1,7 from your remote to access the system menu. Select region from 1 to 6 or set it to 9 for Multiregion. You can also disable Macrovision from this screen.
    Sony DVP-M35
    Insert your disc then press DVD menu button, should take you to menu screen for the film, Then select program button on your remote then selected a few chapters from 2 - 20 say then press play,stop,play,stop until it plays the movie(sometimes works straight off others minutes, it may start playing at chapter 15 but once you have it playing just skip back to the beginning.
    Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
    Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voil. If you don't have good results, disconnect the equipment and repeat.
    Or
    Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
    Or
    Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
    Sony DVP-S500D
    Try the above
    And
    http://www.haldigital.com/hp/dvd.htm
    Sony DVP-S725D
    Hold clear, menu and number 4 then a menu will pop up asking you to type the region codes.
    nick1973's Avatar
    Nov 2006
    97
    Sony DAV-S300
    Or
    Sony DVP-CX860
    Sony DVP-M35
    Or
    Or
    Sony DVP-S500D
    Try the above
    And
    Sony DVP-S725D
    Soupie69uk's Avatar
    Owner
    Mar 2004
    Edinburgh, Scotland
    2,752
    Thanks very much mate.
    A4 1.8T Quattro
    beaker's Avatar
    Aug 2005
    Dundee
    364
    On the same topic, does anyone know how to unlock either of these...
    Sony SLV D300P
    Sony DAV FR1
    I've searched all over but can't find anything for these two.
    A3 2.0TDi S-Line DSG. Akoya Silver, BOSE Symphony, Xenons, Rain/Light sensor.
    Jun 2004
    Ayrshire, Scotland
    122
    Try the following link for unlocking codes.
    Even if your model is not there try the nearest to it. Worked with my last player.
    http://www.dvd.reviewer.co.uk/info/multiregion
    Some players though will not work with a code as far as I'm aware and might need some sort of work on it. Had a Phillips before which required one on the internal wires to be cut. (can't remember what one as it was years ago)
    Cheers.
    A4 1.8T Quattro Sport, Red, 18" B7 RS4's,
    A3 TDI Sport, Lava grey
