Sky InsuranceBadger5
Results 1 to 15 of 15
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    New Road Angel - A common Fault ?
    My New Raod Angel is approaching twelve months old. Recently its begun taking a while to locate satellites (3-4 miles), but on occassion I've driven for 20 minutes. Is this a common thing, may have to get it sent in for a closer look.
    Jun 2003
    World of my own
    9,813
    Re: New Road Angel - A common Fault ?
    I've had mine for 18 months and it always picks up within about 30 seconds
    rickquattro's Avatar
    May 2003
    Rickenback, German Black Forest
    588
    Mine did a similar thing then failed to pick up any satelites at all. Sent it back to Blackspot where it needed a new GPS engine. No quibble, fast return, no charge. Excellent service, but boy did I miss it while it was away!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,658
    Mine can take up to five minutes on occasions. I might ring them & see if I can wangle a free upgrade.
    scbduke's Avatar
    Aug 2005
    Oxfordshire,England
    55
    Had a similar problem with my RA Nav, failed to pick up a satellite for about 20 mins. I've found that rather than putting the unit into standby mode with the button on the front if I turn if off completely with the one on the base then on again it picks up a satellite almost straight away - I guess it clears any duff entries out of the way and allows a clean start.
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    I had a loan of mates "navman" and a couple of times it threw a wobler and couldnt find a satellites for ages as well ! tryed switching off and re-booting didnt work , just had to leave it till it found them!
    DIPS_A4's Avatar
    SEAT LEON CUPRA R (225)
    Mar 2006
    Leicester
    566
    i found my road angel does not pick up any redlight cameras even if i have installed the updates is that also a common fault?
    ive got road angel 2 with laser alert
    Jun 2003
    World of my own
    9,813
    Ermmm it's a speed camera detector, the clue's in the name.
    You can't really jump a red light accidently.
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    [ QUOTE ]
    [/ QUOTE ]
    When you got the GPS engine repalced was it in warranty ?
    May give it a go anyway.
    Jun 2003
    World of my own
    9,813
    I feel naked without mine (I share it with the wife after mine got nicked), the accurate speed readout is just so reassuring somehow.
    May 2003
    588
    [/ QUOTE ]
    [/ QUOTE ]
    Hmm. I think so but not sure. Given the response that I had from them, I wouldn't be suprised if they helped you out after the warranty has expired. As I said, no quibble or attempts to wriggle out of getting it sorted.
    I know what you mean when you say that you feel a bit vunerable without it.....
    Andy101's Avatar
    Nov 2004
    North Yorks
    166
    [ QUOTE ]
    [/ QUOTE ]
    If you have the unit number blackspot shoutbe able to disable your nicked unit i think.
    Will tryand blag a repair on mine
    Jun 2003
    World of my own
    9,813
    Yes I did this, but doesn't really help me. The scum that stole it is hardly likely to have the intelligence to even try and synch the database. Blackspot can't disable the actual unit as it is only a receiver, all they can do is disable any updates.
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    ive got a road angel classic and it wont find any signal? blackspot told me it was due to the audi windscreen but if you lot are getting a signal then it must be the unit
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    1,836
    anyone running the road angel plus , and how does it stack up against the Origin B2 ????
    wots the better item?
    I bought a convertable in the wettest country in the world who says Scotsmen dont have a sense of humour !
    "Lets fire up the Quattro" DCI Gene hunt,,,,,,,ashes to ashes
