Hello, I recently bought a ctek mxs 5.0 car battery charger, it came with a two prong plug. this didn't fit in my outdoor weatherproof socket (which only works when closed) as the plug stuck out too far. So I very foolishly cut the plug off thinking I could simply put on a UK 3 pin plug, unfortunately upon closer inspection-after the the deed was done-the ctek plug was fused at 16a and the highest fuse/plug that I can find is 13a. So now I have a £50 charger with no plug. Could you please advise how I best correct this, thanks, in advance, andy
P.S. as you can tell by my above tale of woe, i'm a complete electrical novice so feel free to, if you are kind enough to answer, to put it into laymans terms.
TECHNICAL SPECIFICATIONS
Charger model MXS 5.0
Model number 1049
Rated Voltage AC 220â240V AC, 50â60Hz
Charging voltage 14.4V, 14.7V, 15.8V
Min battery voltage 2.0V
Charging current 5A max
Current, mains 0.65A rms (at full charging current)
Back current drain* <1Ah/month
Ripple** <4%
Battery capacity 1.2â110Ah up to 160Ah for maintenance
Model number 1049
Ripple** <4%
