JBSDNA Tuning
    Kaibo's Avatar
    Jun 2011
    Middlesex
    217
    Post Thanks / Like
    Plasma TV has lost its red
    My Plasma tv has lost its red, ages ago when I was using a standard monitor connection, d sub, it lost it's red, I just put it down to the lead as all other sources were fine, changed the PC to DVi and forgot all about it. Well now all sources and even in menu mode has now lost its red, any body know where to look as a possible cause of this, I'm guessing I'm now looking at a new TV which I need like a third armpit.
    Cheers Kai
    beanoir's Avatar
    Sharpest Tongue in the West
    Jan 2007
    51 Degrees North
    2,014
    Post Thanks / Like
    If it's definitely doing it from all sources and you haven't got picture being fed through an AV amp (via HMDI or similar) and can be 100% sure that it is the TV, then you've likely got a problem with the YSUS (or ZSUS) module, which in may TVs is relatively easy to swap your yourself (no soldering required).
    Kaibo's Avatar
    Jun 2011
    Middlesex
    217
    Post Thanks / Like
    Yeah it's on all sources, I did have a dry solder somewhere as had a power issue a while back, maybe or hopefully it's something like that, thanks for the info, will let you know how it goes.
    Cheers Kai
    Kaibo's Avatar
    Jun 2011
    Middlesex
    217
    Post Thanks / Like
    Cheers Kai
    Sep 2011
    Heysham Lancashire
    Post Thanks / Like
    Hmm Plasmas are Notorious ffor losing there gas after 3-5 years
  1. Plasma TV Repair.
    By unkle in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 26th October 2011, 19:09
  2. FS: S2 / 80 / 90 Plasma gauges
    By s2_bo in forum S2/RS2 Forum
    Last Post: 8th May 2009, 21:30
  3. lcd or plasma
    By wackojacko in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 28th March 2008, 20:46
  4. New Plasma
    By stoakseya4 in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 23rd March 2007, 00:26
  5. Sell the Plasma?
    By QuantumJohn in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 30th August 2005, 15:51
