AMD TechnikSky Insurance
Thread: TV signal
    Oct 2008
    880
    Post Thanks / Like
    TV signal
    lve been using sky for years now and havent used my ariel signal for as long. l have a Samsung TV that has freeview in it but because of where it is in the room l never hooked it up. lm away to moved the tv upstairs to my 'play' room and replace it with a 8 series. My question is , is there any way to feed the signal through the house mains suppy like you can with a LAN?
    Nov 2011
    15
    Post Thanks / Like
    I dont believe there are any devices on the market for this, best you can probably do is a RF video sender sort of running some more coaxial cable runs.
  1. O2 network/signal.
    By stacey bear in forum Rants & Raves
    Last Post: 5th June 2011, 22:44
  2. voda sure signal
    By fingermouse in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 23rd August 2010, 14:19
  3. A4 B6 - Reverse signal over CAN
    By motosparkz in forum VCDS (formerly VAG-COM) forum
    Last Post: 11th May 2008, 15:00
  4. S3 Radio - no signal!
    By Spacecowboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2008, 12:16
  5. speed signal.
    By ajmackie in forum General Technical / How To
    Last Post: 28th October 2004, 17:29
