DPMEM Tuning
Results 1 to 9 of 9
    Sep 2010
    409
    Post Thanks / Like
    Any networking experts here?
    I've recently bought a tv that has internet capability. However I need to buy a wireless lan adapter to use the wifi (it's in my bedroom).
    Is there anyway that I could get a wireless repeater and run cat5 into the tv?
    May 2010
    14
    Post Thanks / Like
    I did looked at this not a long ago since I have 2 LG TV with network capacity.
    You can hook it up with "bridge" which you can network cable into the bridge which have an wifi connect to your wifi modem.
    Alteratively - Use the router. I am researching on this more at the moment before I decide to buy router or modem but at the moment I am changing the internet company, I am at the moment with Virgin and want to change to Sky so let see! Maybe different Internet company.
    Audi A3 2.0 TDI Sport 3dr Black. The Murdered Out Project!
    So much to do so short time! List to do - Neverstop list!
    Running on Standard at the moment. Wont be so standard near date! Watch this space!
    Feb 2009
    Aberdeen
    1,226
    Post Thanks / Like
    You can run LAN over power lines, that'll have a CAT5 connection on either end. Wire one into the back of the router, and the other into the TV. I think Belkin are the advised manufacturers, but there's bound to be cheaper ones kicking about too. You just need a spare wall socket at the router and at the tv.
    Google "LAN over mains" or something along those lines.
    2008 8P2 S3 - Black with black grill, lots of extra + LED DRLs and plate lights, MY11 rears, Evoms CAI, Milltek TBE, H&R ARBs, H&R 25mm springs, genuine BBS RS861 "Speedlines" 8.5x19 ET48, R8 Brakes (Brembo 4-pots/AP 362mm rotors, custom DaveB carriers) - - - 317bhp, 295lb/ft - might be mapped
    Sep 2010
    409
    Post Thanks / Like
    Decided to go for a usb wireless network jobby. Thanks for the replies though guys. The network through the power lines sounds like a great idea!
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    I'll be doing the power lines thing myself, Devolo
    seem to be rated.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    Mar 2011
    93
    Post Thanks / Like
    Powerlines are the way forwards - they "Just work", and for any given distance, seem to have much better bandwidth and link stability than wifi.
    Sep 2010
    409
    Post Thanks / Like
    I'm still considering this, however I have a feeling that my ground floor is on a different circuit to the upstairs. So I don't think it'll work. But is there anyway I can test this out?
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    In a normal British house you should be okay. Not an electrical expert but I think if there is only 1 main switch in your consumer unit then you'll be okay.
    I have them in my house now and they work great!
    52
    Post Thanks / Like
    powerline works you have to make sure they are encrypted properly as some versions jump phases so several houses can see each others devices. if you wanted to keep it simple just make a wireless bridge onto your access point and will work perfectly
