Sky InsuranceVolks Autos
    Oct 2004
    Check Engine Light
    I just bought a 97 A4 1.8, it has about 90k on it and the check engine light comes on. I took it ot the local audi dealer here and they say that it is very common and nothing to worry about, has anyone else had this issue and do I leave it alone or should I get it taken care of? Any help would be great since I have had honda's forever and this is my first audi,
    also could anyone tell me the lug pattern? Need to buy some new rims.
    thanks in advance
    Nov 2003
    Orem, Utah, USA
    144
    Re: Check Engine Light
    Yes, you should probably worry about a CEL. If it is flashing, it's a worse problem, if it's just on all the time, it's not AS serious, but should still be taken care of. See if you can find someone with a VAG-COM near you to check it out for you. As for the lug pattern, someone else will have to help you there.
