AWEsome GTIBackdraft Motorsport
    rickyquicky's Avatar
    Dec 2008
    London
    338
    Post Thanks / Like
    Taking the outer CV joint off from shaft?
    As above really, replacing both outer CV joints on my A3, how do you get the joint off of the shaft? Is it just a case or whacking it with a mallet?!
    Jun 2010
    Glasgow
    Post Thanks / Like
    yup, hold the joint straight and give the back a good whack..
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,707
    Post Thanks / Like
    or wind the bolt back in, it will push the CV off the shaft
    Dec 2008
    London
    338
    Post Thanks / Like
    Cheers guys much appreciated!
    Was worried there might have been a cheeky circlip hiding somewhere before I started bashing it with a hammer!
    On a side note, I have about 1mm of play side to side in my inner CV joints when I twist the shaft, is this normal or do you think thats excessively worn?
    Byzan Pics's Avatar
    Apr 2004
    10,707
    Post Thanks / Like
    there is a snap ring hidden inside the CV, but you need to overcome that to push it off, either the hammer trick or wind the bolt will be fine.
    I wouldn't worry too much about the play, if it wasn't making noises before once you have cleaned and regreased it will only be better
    Dec 2008
    London
    338
    Post Thanks / Like
    But am I right in thinking there shouldnt be any play at all? Or is some side to side motion normal?
    If im spending the time doing it I might as well get it all 100%!
