KowalskiForge Motorsport
    Sep 2009
    Gloucestershire
    54
    Post Thanks / Like
    OIL TEMP SENSOR PLUG LOCATION AEB 1.8T
    The oil temp has stopped working on my b5 A4 1.8T
    Have done a bit of research and found the oil temp wire (an open ended spade connector) is loose and plugs to the oil cooler/housing, but can't see where? Have found the oil pressure plug (rubber shrouded plug), but can't see where that temp spade connects to. Any ideas?
    /sprint_48 / Audi b5 A4 1.8T //// // //
    Badly Parked Dubs
    Byzan Pics's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    10,707
    Post Thanks / Like
    the shrouded one is at the back and the temp sender is mounted more on the side of the same housing. You may have to remove the 3 screws holding the header tank in place and move it to one side so as to gain a decent view
    Sep 2009
    Gloucestershire
    54
    Post Thanks / Like
    Cheers for the quick response! I'll have another look at it
    Badly Parked Dubs
    Sep 2009
    Gloucestershire
    54
    Post Thanks / Like
    Ok, just removed the header to gain some more light, but still can't see, or feel, where it plugs to. Is it on the right or left of the pressure plug as you look down into the bay from the front of the car? Either I'm being daft or something's not as it should be
    Badly Parked Dubs
