Volks AutosJMB Retrofits
Results 1 to 9 of 9
    Re: Explain your aviators......
    General Zod from Superman 2. I chos ethe name Zod for anonymity the first time I signed up on an internet forum, because I liked the sound of it, not because I am a particular fan of the film.
    I need to get around to choosing a different avatar.
    imported_Macduff
    DIS (in)accuracy
    How close to reality is the DIS average MPG? We've had our PD130 for a couple of months and we're getting about 41MPG. I guess this will improve with time but the DIS is showing around 44MPG. Is this normal or do people find that it's reasonably accurate? Given that it's a Ł300 option I'd expect it to be spot on.
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Dave
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    Re: DIS (in)accuracy
    I'd say it's about 10% off in most cases when it comes to fuel consumption.
    Mar 2004
    Cheshire
    922
    has anyone noticed how the 10% always promotes economy!
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    [ QUOTE ]
    [/ QUOTE ]
    well it certainly isn't going to promote my maniac driving style... [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    Oct 2004
    41
    The thing i think is really silly is the instantaneous MPG reader that can jump from 200mpg too 35mpg, I mean what is the point of it, its no use. I just use the other MPG reading as that gives an average. Was told by someone that the reason for it jumping back and forth is because when your foot is off the accelerator there is no diesel going into the engine, that sounds a bit far fetched to me.. there must be something to keep the engine going!
    regards
    Jonathon
    Mar 2004
    Cheshire
    922
    there is obviously some fuel going to on idle! It is probably down to the formula it uses to calculate the instantaneous mpg.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,505
    [ QUOTE ]
    regards
    Jonathon
    [/ QUOTE ]
    It's true, when the car is in gear and coasting (no throttle), the fuel pump switches off, so the car is actually more economical when constantly in gear, including slowing down?!
    Apr 2003
    England, North West
    425
    Mine runs about 5% high on average.
    For the accuracy freaks out there. You can get it adjusted during service ... [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
