Badger5DNA Tuning
    Aug 2009
    7
    Post Thanks / Like
    ALARM IS A PEST (common fault?)
    Over the past few weeks my alarm has been going off after i have used the remote keypad to lock it, also my rear wiper has stopped working and on the dashboard display keeps saying the boot is open (when it is definatley shut). Due to this my battery went flat over night as the courtesy light stayed on, Mr AA came to jump the car and said it is a common fault with a3's as there is one unit in the boot that operates all of the above. Has anyone else come across these problems as it is driving me nuts.
    Jun 2010
    9
    Post Thanks / Like
    Id check the boot area first. The switch which turns the boot light on and off and which is also linked to the dash (dis dispay) is built into the catch. Id try and check that first to see weather thats sticking or faulty. Check inside the boot lid and also and check the loom running through into the car from the boot. It maybe a module fault but its worth checking the following first. A simple test for the boot light/alarm problem is to unplug the wiring to the switch in the catch and see if the boot light goes out. If it doesnt youll have a wiring issue or a module fault. If it does then its a faulty switch.
