Backdraft MotorsportRevo Technik
Results 1 to 7 of 7
    Sep 2009
    12
    Post Thanks / Like
    F8 fuse keeps blowing + eng man light on
    The title says it all really. My eng man light is on but I'm not sure this is connected to the fuse F8 which keeps blowing. Does anyone know what the F8 fuse does? It is located in the fuse box in the engine bay. I can replace it (10amp) but as soon as I turn the ignition it blows. Car still runs fine
    Sep 2009
    12
    Post Thanks / Like
    Sorry, it's an Audi A3 8p 2.0tdi sport.
    Jun 2010
    9
    Post Thanks / Like
    F8 is (actuators, sensors, radiator fan, main relay for ignition coil.) I have an 2.0fsi petrol and thats out of my manual. obviously its going to differ slightly but should be similar. Best bet would be to plug it in on the diagnostics mate.
    Jul 2010
    Post Thanks / Like
    hi, i have a very simular problem on my 04 reg a3 tdi sport dsg - the eng mgmt light has been on,i have been told its due to the "inlet manifold flap motor"? as the engine runs fine and drives well i have put off the repair... HOWEVER,i have recently discovered (only in very heavy traffic - 1hr+) that the engine will start to overheat eventually as the Fans do not cut in!! after investigating i have found that FUSE F8 (10A) was and keeps blowing... do your cooling fans cut in ok if its left running stationary ???
    im still not sure wot the problem is (awaiting answers from so called Audi experts) but will let u know if /when i suss it out...
    please let me know if u Have/do sort your problem out.
    Jul 2010
    Post Thanks / Like
    ALL SORTED !!! after a little research,i decided to replace the "intake manifold flap motor". got one from GSf for about £150 and fitted it myself (on inspection i found a broken plastic gear inside the old flap motor) ,also taking time to clean out the "Egr valve" as recommended...
    The engine instantly seemed more responsive,after replacing the fuse (F8 - 10a) i also found that the cooling fans and air conditioning were working perfectly
    however the engine emissions light was still lit on the dash,even after trying to reset the e.c.u. by removing the battery/ignition key methods...
    with the help of a friend and a snap-on diagnostic box ,managed to delete the logged codes ,lights out and all has been well since (2+ months) so im back in love with my DSG
    Banned
    May 2011
    30
    Post Thanks / Like
    sorry to sound liek an amateur but my car has throttle boddy fault i cleaned the throttle body and egr valve until they were sparkling,
    my cooling fan still kicks in AC heaters and everything seems to work fine, so what other fans can this F8 fuse blow and is the only soloution changing throttle body im stressed out
    please some one private message me what to do and what can blow with this fuse
    thanks a million
    chrisa4quat's Avatar
    Sep 2004
    664
    Post Thanks / Like
    I'd stick a new throttle body on it. Very common
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
