EM TuningMonster Motorsport
Thread: Hub sizes?
    fallmonk's Avatar
    Turbo Sport
    Jun 2004
    Glesga,home of the rain god!
    1,836
    Hub sizes?
    Lookin for help , mate bought a set of alloys(aftermarket) off a AUDI 90 20v on a F reg(1989) and planned to fit them to his 80tdi L Reg(1994?) but says they dont fit on the hub? is this right??? did audi change it when they "facelifted" the shape???? many thanks [img]/ubbthreads/images/graemlins/froggie_red.gif[/img]
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Re: Hub sizes?
    A friend of mine had one of the late 80's shape 100's which used four hole mags on a 14inch rim, my mid 90's 100 (500se) uses five hole mags on a 15inch rim. Not sure on the 80 or 90 models though it would not surprise me if the hub changed on those too?
    1,361
    Re: Hub sizes?
    It's quite possible that there's a number of differences to do with the bolt pattern and most likely the offset.
    As an example old A3 wheels do not fit the new A3 and vice versa.
    You can buy hub adaptors which you bolt to the hub and then fix your wheels to, but these aren't available for every car and is dependent on the offset of the wheel as to whether you can get away with what is effectively a spacer as well.
