I
imported_scrupes
Hi all,
i've owned my 96 a4 2. for nearly a year now, i noticed around 4000 miles ago that she runs crap around 1500 - 2500 rpm? its like the throttle is intermittent or the engine cradle is loose?
i do the most of the work myself and whilst replacing the bottom armsand track rod ends i looked for loose parts and worn mounts under the frontend... nothing?
i've read about temp. sensors and MAF sensors going wrong and i'm confused.
its not drive by wire, so could it be the throttle position sensor?
please help, cos i can forsee me ripping it all out only to get no further forward and incurr loads of costs along the way!
any one else had a 2.6 motor'd a4? any similar probs? cheers for any info even if you think its insignificant! /ubbthreads/images/graemlins/beerchug.gif
