AH FabricationsChris Nott
    imported_Kyoshi
    Removal of Accelerator Pad
    Can anyone explain how the A4 (1996 model) plastic accelerator pad can be removed from the accelerator pedal? There's a spring behind the pad and a small hole (possibly pin) to the left of the plastic pad but I'm stuffed if I can figure out how to remove the pad?
    TIA!
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    Re: Removal of Accelerator Pad
    the pad cannot be removed it can be replaced by the whole pedal being changed, that is the ONLY way
    imported_Kyoshi
    Thanks for the information, I suspected so.
