Having done a brief search of the forum and not had much success, does anyone have any info on painting the chrome surround on the inside of my S3 headlights??
JAFFASPORT - 2001 Facelift, 218/237/216bhp AMK, Absolute Red, Thrashed to Death, Car Park Dents Everywhere, Kei Flux's, Knackered Shocks, Scuffed Rear Bumper and in need of a good Hoover!!
BLACK EVO BEATER -2001 Facelift, 349bhp AMK, Ebony Black, Blue Seats, 4 Wheels, Brakes, Exhaust, Headlights, Sh!t loads of boost and up for sale!
Hello mate.
You need to carefully remove the clear lens by gently heating up the complete edge as these are bonded on. Once heated it should come apart easily. As for painting the chrome this is not the case. You need to use something like T-cut to remove the chrome coating. This is certainly the case in other cars and I'm sure Audi can't be much different. I'm wanting to do my A4. I'll get round too it soon I'm sure. Let me know how you get on
If it's got t*ts or wheels, it's TROUBLE!
If you look inside most modern headlights they have a few components within. The idea is to make black the outer part to give the smoked look. Obviously the insides differ from car to car but some look really good. I've got xenons so they have the projection lenses so this mod is possible. Not sure whether to yet as not seen my model with it done
I've got a '98 A3 1.6 so I'll have to have a proper mooch at it when I get it back from the surgeon.
i have done this to corsa b headlights stacks of times, to heat the bonding that holds the glass to the headlight place the light in boiling water, then gently prise them apart after 5 mins or so and place back in water if necessery. the first time i tried it i was told to put them in the oven on a low heat but after sevral headlight lens's and trips to the scrappy i reverted to water and it works a treat!!![]()
My lights aren't the projector type. There is however a separate piece around the front of the lamps inside and obviously the piece that separates the two sides of each lamp that I could paint but like TorqueTerrorist said I'd rather see my type of lights done before I leap in and rip mine apart.
Cover with some Lamine X film which is a lot quicker and easier to do plus if you ever don`t like it just heat the film up and it will peel off.
06 Audi 2.0 PD140 Sport TDI Quattro S-LINE.
Old engine 330 bhp @ flywheel 263 bhp @ wheel 490 lb torque. Audidriver write up HERE
Now stripped and playing with an uprated Cryo treated engine fitted with bigger turbo,water/methanol,uprated injectors etc etc.Wanting 400 bhp and 500 lb torque.
PD140 ported head for sale
Other car 500+ bhp MK4 Golf R32 turbo.
My car with lamin-X on left and normal on right.
