Forge MotorsportDTUK
Results 1 to 8 of 8
    spence_star's Avatar
    Jul 2007
    201
    Post Thanks / Like
    How to replace pollen filter and fuel filter?
    Guys,
    Ive decided to service my own car i have a 1996 A3 1.8T
    Im trying to find an online hanes manual but no one seems to have one, so i was wondering if there was a guide or if someone can tell me where to locate them.
    Spence
    JimC64's Avatar
    Apr 2009
    Glasgow UK
    100
    Post Thanks / Like
    good question spence, sorry, I can't answer it unfortunately.
    I also have been looking for a write up / walk through ( pics would be good too ) of a pollen filter change on an A6 (07) Plate
    I hoped some of the older / more experienced / hands on sorta guys mighta done one by now, but no luck
    Jim
    MY2007 Audi A6 2.0 Tdi SE 176bhp Stratos Blue, badged as 3.0 Tdi Quattro.Front & Rear park assist,Comms Pack High,Sline grille badge added, 17" TT Trapeze alloys,Rear tints,Dipped bulbs 80W,Mainbeams & Foglights 100W,Number plate LED's,Interior LED's,First Aid Kit,Bootliner,Mudflaps front & rear,Calipers & hubs painted & DRL Led's
    zeeeebo's Avatar
    Lifes one big laugh
    Jul 2009
    worthing
    417
    Post Thanks / Like
    i did a fuel filter change the other day one workd... what a killer! the fuel filter is located on the drivers side about 1/4 of the way down the sil if you put your head under about a foot away from the back wheel you will find it.
    it has a clipped pipe going in and a clipped pipe going out! i spent hours trying to work out how to disconnect the pipe but really couldnt work it out! in the end i managed to snap one of the clips but they both came off in the end! if you want my honnest opinion get some fuel hosing from halfords and cut the clips off and jubelee the new hose onto the fuel filter!
    i will try take some pictures of what i mean if i have a chance tonight, drop us a pm if you want them!
    i dont know if there is a proper way to get the fuel pipe clips off as i couildnt figure it out at all! i think you have to put a screwdriver in the 2 holes and push the clip out!
    Aug 2009
    Post Thanks / Like
    I found an article on how to replace the fuel filter and hope this works on you:
    Fuel Filter Replacement
    hope this helps!
    can't find some pollen filter tips though...
    _________________
    Satisfaction is derived from a job well done.
    Jan 2009
    11
    Post Thanks / Like
    A3 Hi the pollen filter on your A3 is located on the nearside if you open the bonnet and look at the plenumb chamber cover there is a little flap that lifts up and the filter is behind there.
    A6 the pollen filter is behind the glove compartment just remove the plastic under panel slide the cover out the way and remove the filters there are 2 stacked on top of each other it sounds strange but once removed you will be able to see what I mean its simple!!
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,811
    Post Thanks / Like
    fuel filter replacement:
    http://forums.vwvortex.com/zerothread?id=1276409&page=1
    Just be careful with the clip. There is a small trick to remove unclip the hose without the use of any tool. Take you time, if needed, depressurize the fuel system (remove the fuse) and wait for 30mins.
    removing the clip: http://forums.vwvortex.com/zerothread?id=2979787
    As for the the pollen filter, it's very easy mate. As red-line explained above.
    Hope this helps
    ^^ In my opinion
    Apr 2010
    38
    Post Thanks / Like
    Sorry I read in this forum on the A3 2005 the pollen filter is behind the glove box?
    Or is it in the bonnet?
    Oct 2008
    880
    Post Thanks / Like
    On my model, 2008, lve heard its in the passenger footwell under the glovebox. Will confirm today.
