I
imported_rst99
I have a 97 Audi A6 2.4 which has recently developed an irritating problem. When I start the car I get 3 warning beeps telling me there is a brake problem, then another 3 beeps telling me I have an oil pressure problem. When this happens the aircon stops working as does the rev counter.
Originally the problem was intermittent - the rev counter and aircon would come back on mid journey. But recently it has been a permanent fault. I have replaced the front and rear brake pads and rear disks since the problems started (which made no difference).
If this is an electrical fault where should i start? i have checked the battery terminals (the battery was replaced recently too).
If it is an ABS unit problem would the problem start as intermittent and gradually get worse or would it instantly stop working.
Any help appreciated.
Stu
Stu
