KowalskiW8 Performance
Thread: Sat Nav Info
    May 2009
    Post Thanks / Like
    Sat Nav Info
    Hi All
    Just got my new S5 ...... sexy as hell.
    The Sat Nav (fitted) works well, however, on approach to a roundabout it will pre-warn for ,''take the second exit, straight on, continue on the A1''. Brilliant I thought........ untill I arrived at the roundabout and the Sat Nav then commands ''Turn left now'' ........ which is not so good as this is the first exit !!
    Not a huge problem but an annoying one.
    Does anyone else get this ?
    Can I fix it ?
    Audi, apparently, know and acknowledge that the issue is there !
    Help !!
    Many thanks Mark
    Staz's Avatar
    is a retronaut
    Oct 2006
    Berkshire (mostly)
    6,008
    Post Thanks / Like
    Very weird! Never had this. are you sure it wasn't a roundabout that's not there anymore? i.e there WERE 2 of them then it warned you on the approach to the first but then as you effectively appeared on the other side of it it didn't have time to give you the approach warning for the second.
    Leon AKA Staz, Stazmataz, Stazalicious or Stazatron. 8P2 S3
    s8craig's Avatar
    Jul 2005
    Manchester
    1,102
    Post Thanks / Like
    No, it happens all the time on MMI 3G, getting pretty annoyed with it now for roundabouts. But my MMI 2G did this until updates came along and fixed it.
    No 3G updates for mapping yet.
    My Retrofit Website
    http://www.tclsatnav.com
