Volks AutosEM Tuning
    imported_simonmcc
    Slow to start TDi
    I was looking at a 1999 Bora Sport 110 TDi on Saturday, and it all seemed fine, except that when you turn the key it turns over a few times before it starts. I didn't see the car when it was cold, so this is from warm
    Any ideas? If this was common/easy to fix I would buy this car!
    S.
    imported_simonmcc
    Re: Slow to start TDi
    [ QUOTE ]
    28v6 said:
    Glow plugs!! What mileage was on the vehicle whe you looked at it??
    [/ QUOTE ]
    66000 miles, could it really be the glow plugs, even when the engine is warm?
    EDIT: moschino - It cranks mayme 4-5 times, but then fires up immediately, and runs fine
    S.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    they all smoke a bit on start up black or blacky blue color if there are BIG clouds then there maybe a problem, its more then likey it will one of the thing posted before if you get it just give it a good service and check/change the glow plugs
