DPMBadger5
Results 1 to 14 of 14
Like Tree1Likes
  • 1 Post By Andy H
Thread: B7 A4 FRONT GRILLE REPLACEMENT
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Post Thanks / Like
    Since getting the B7 A4 I always hankered after the black grille to replace the standard chrome one.
    I thought they would be a bit expensive but they are only 130 pounds from the dealer and come complete with 4 rings and S-Line badge. That’s a good price for a body part that transforms the front end of the car. Pleasantly surprised so I was. I thought I might as well share some pics from the changeover in case any other Audi owners are considering doing the same.
    DISCLAIMER
    I accept no responsibility for damage of any kind that anyone experiences while using this guide to carry out the same modification. It worked for me.
    STEP 1 – GET THE CAR SAFELY UP
    STEP 2 – WHEELS OFF
    STEP 3 – REMOVE UNDERTRAY AND LOOSEN WHEEL ARCH LINERS
    Remove the torx fixing screws from the front of the liner to the top. Only half of the liner needs to be movable.
    Pull the liner out of the small lip on the arch and fold it back so that it can be held behind the brake disc.
    This then allows access to this black plastic bracket that couples the side of the bumper cover to the main body.
    10mm spanner for the hex nut and torx screwdriver for the two screws that are arrowed. These screws are just out of shot! Sorry.
    Remove the undertray - NOTE: This may not actually be necessary (SEE WHY IN STEP 4)
    STEP 4 – SLIGHTLY LOOSEN FRONT END FIXING SCREWS
    Area of interest here is the circled spot. About 15cm under here, there is a torx screw that only requires something like a quarter or half-turn. If you are using a socket and torx bit bit and extension to get in here then you will probably loose the socket and torx bit on the way back out. That’s where removing the undertray comes in handy. If you have long-neck torx screwdrivers then you shouldn’t have to remove the undertray! That’s not a bad option really!
    The pic below shows where these part-turned torx screws fix onto the bumper cover.
    You can also remove the torx screws that secure the top of the grille to the front end.
    STEP 5 – REMOVE BUMPER COVER SECURING NUTS ON EACH SIDE
    You now see the screws that secure the front bumper cover. The pic below shows the hex nuts removed. This was 10mm hex if I remember correctly.
    The driver’s side is more straightforward, but on the passenger side the windscreen-washer reservoir tank obscures your access. Don’t worry though, you can push the tank forward slightly to get access but you will need an extension and 10mm socket bit to get to it properly. It’s no bother though.
    The bumper cover can now be pulled out from the car. You will have to unplug the spotlamp power connector. There’s enough give to put the bumper cover on the mat first and then disconnect it.
    STEP 6 – REMOVE THE OLD GRILLE
    This is secured to the bumper cover by 10? Torx screws. Removal is simple.
    STEP 7 – INSTALL THE NEW GRILLE
    STEP 8 – PUT IT ALL BACK TOGETHER NOW!
    Such a big, yet subtle difference for the money. I hope this has helped somebody. Job time was 3 hours here, but to do it again would probably take me 2 hours.
    Good Luck!
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    871
    Post Thanks / Like
    Black's the way to go looks a lot better!
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Nov 2008
    104
    Post Thanks / Like
    Hey mate where did u got the black grill to buy . I am looking for one right now ..
    johnnythepie's Avatar
    winkywonkywaanky
    Apr 2009
    Solihull
    1,456
    Post Thanks / Like
    Give stoke audi a shout, or pm pjmspeedy
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Post Thanks / Like
    Quote Originally Posted by jaceyq View Post
    Stirling Audi. Any dealership will do though and the parts price should be the same (approx 130 quid) regardless which dealership you buy from.
    Audi A4 S-line Avant 2.0T FSI
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    I did mine too. Let me know what you think...
    http://www.facebook.com/photo.php?pi...&id=1647450843
    If it's got t*ts or wheels, it's TROUBLE!
    Mar 2009
    Stevenage
    289
    Post Thanks / Like
    What do you think with new splitter fitted today??
    wyliss's Avatar
    Aug 2004
    North West
    144
    Post Thanks / Like
    I like that splitter, where did you get it from ?
    I'm also considering the black optics grille, are you pleased with it?
    Must admit it does make the car look quite stealthy if you see what I mean.
    wyliss's Avatar
    Aug 2004
    North West
    144
    Post Thanks / Like
    Jr, the car looks superb with that grille.
    Is the grille itself black or is it the same colour as the number plate holder i.e. a dark grey ish colour?.
    The reason I ask is because I was just wondering if you need to purchase the number plate holder too so it matches the new grille.
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Post Thanks / Like
    Cheers big chap. I just used my original one, dark grey. Think you can get them in black if that's what you're looking for.
    May 2010
    West Sussex
    75
    Post Thanks / Like
    Got to agree that the black grille is the business. This is mine;
    phulla likes this.
    '08 A4 Avant 2.0T S-Line Special Edition in Mauritius Blue
    Feb 2011
    11
    Post Thanks / Like
    2007 Audi A4 2.0T FSI quattro S-Line Special Edition Black
    2007 A4 2.0T FSI quattro SE
    30
    Post Thanks / Like
    mate can i ask where did you get the spilter it looks good
    wyliss's Avatar
    Aug 2004
    North West
    144
    Post Thanks / Like
    Seat dealer or TPS. Approx £30 plus vat.
    A4 B7 2.0T FSI S-LINE Akoya Silver, Xenon plus pack, RS 6's, MFSW, Phatnoise, Auto dimming mirror, Light/Rain sensor, Bose, Isofix, Split folding seats, Rear side blinds, Rear window blind, Centre armrest, Auto boot Lid, Cargo parcel net/hooks,Loadliner & Votex Rear Diffuser.
