JMB RetrofitsVolks Autos
    imported_paranoico
    Programming Keyless window closing / opening
    Hello...
    I didn't know where to place this post, so I guess tech swould be the most appropiate place.
    I have recently acquired a used A6 V8 and it only had one key. This is the master key w/remote (switchblade) and it is supposed to open and close my windows if I keep the button pressed (My previous Allroad did this from the first day) but it doesn't.
    Is there a way to program the key to do this? Also, anybody know how much it costs to get a second key?
    Thanks,
    Paranoico.
    Mar 2004
    USA
    275
    Re: Programming Keyless window closing / opening
    If I recall, you need a VAG-COM to do the reprogramming if you don't want the dealer to do it. There is a way to reprogram a key to unlock the doors, but I don't think it includes the window up/down function.
    Second keys from the dealer are around $80 if I recall.
    Nov 2003
    Orem, Utah, USA
    144
    To learn how to program the remote/central locking features with a Vag-com go to http://www.ross-tech.com/vag-com/cars/audiB5.html I have quted the part of interest below.
    35-Central Locks: -- KWP-1281
    VAG-COM Works fine (note: pre-'97 A4's may not have this module).
    Recode locking options
    [Select]
    [35 - Cent. Locks]
    [Recode - 07]
    Enter the coding below
    [Do It!]
    Write down the existing coding for future reference.
    A4 pre-1998 with Delta radio and anti-theft system
    Standard Coding: 03468
    A4 pre-1998 with Delta radio, anti-theft system and keyless entry
    Standard Coding: 12172
    A4 1998+ with Concert/Symphony radio and anti-theft system
    Standard Coding: 03340
    S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
    Standard Coding: 16140
    Add the following options to your coding number:
    +64 Windows up, sunroof close, and windows down with remote.
    -04 One touch unlock of all 4 doors and trunk
    -1024 Remove horn honk when arming
    +32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
    So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
    add 03340+64+32= 03436
    Let me know if youhave any specific question, I have done this on my A4 also.
    -Brad
    Nov 2003
    Orem, Utah, USA
    144
    PS. The coding is the same for an A6/All-road, i.e. it might be stored in a different place, but you still add or subtract the same numbers off of the code.
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    those codes he has supplied are correct!!!!!!!!
    Nov 2003
    Orem, Utah, USA
    144
    Follow me, I think that option is listed in the list I gave. You should only have to add 64 to the existing code.
