Volks AutosJMB Retrofits
    evilbow's Avatar
    Wheels urgently needed
    Feb 2009
    glasgow
    183
    Question driver door shutting problem
    sometimes when i get in my newly purchased audi a3 1996, when i pull shut the door it wont close properly after a few attempts still the samebut have found if i put my window down an open door from outside then close it it shuts! lol anyone have sim problem before or know hopefully a quick and easy fix?
    Mar 2009
    Have you tried spraying some WD40 into the mechanism?
    c_dog's Avatar
    Apr 2008
    Sussex
    99
    Is it this kind of not shutting properly?? Door wont shut properly...
    Apr 2009
    76
    same problem here too. if i shut the door normally or fairly hard it sort of rebounds back half shut on the latch. then you can push it fully shut. It works fine if you shut it gently.
    strangely i drounded the lock in WD40 and it worked fine... for a day then started playing up again
    audi80sport's Avatar
    is it home time yet?
    Sep 2007
    kettering
    116
    if i remember right its cause your shutting it so fast the clogged up locking mech's dont move that fast therefore letting it swing back open
