    Feb 2009
    Unhappy Help installing my sub
    Hi, I have a 54 plate A3 and want to install my sub. A few people have looked into it but we cant see where you feed the cables thru from the engine bay into the dash etc. as there are no obvious gromits or anything to run them thru i signed up on here to ask you guys??
    Jan 2009
    107
    I have a similar problem on a 2001 A3, i just cant get the power in!!!
    alijames's Avatar
    Feb 2008
    Oxford
    1,017
    Scott,
    Getting the power into an 8L is relatively easy. There is a spare grommet under the plastic flap on the passenger side between the windscrenn and the suspension mount. Comes out behind the glovebox
    Albert. There may be something similar on an 8P, but as I have not got one, can't help I'm afraid.
    Cheers,
    Alistair
    "Why don't you listen to something really classical, like Mozart, Mendelssohn or Motorhead?"
    Arnold Rimmer, 1988
    Commuting & Weekend Fun:
    Yamaha YZF-1000R Thunder Ace in Blue/Black
    Practical Alternative (Still fun though!!):
    S3 2002/51 AMK Silver, Symphony II + Bose + xCarLink + AndyMac Stealth Sub, Metallic Mirrors, Heated Black Leather, Cruise control.
    ROLTYA3TURBO's Avatar
    essex boy :)
    May 2009
    essex, uk
    247
    i put my power cable through the grommet about half way down the bulhead on the passengers side(look at the bulkhead slightly to the left of the airbox and look down)it's a bit fiddly but it's a hole you can use, there is already a cable runnin through and you can easily push the other wire through which comes out behind the passenger side carpets.
    '98 azure blue a3 1.8t, forge 007p,KW 40mm springs/shocks,18" polished rs4's,s-style chrome mirros,black diamond front 20 groove discs,ebc greenstuff pads,painted and decal'd calipers,colour-coded engine cover,aero wipers,chrome indicator bulbs,l.e.d xenon sidelight bulbs,h.i.d xenon headlight bulb kit,let the work begin!
    Latest addition - s style chrome mirrors
    Next up - remap,exhaust
