    Jun 2008
    Epsom, Surrey
    233
    PowerFlex Bushes - fitting
    Can anyone gives me a heads on how bushes at the front and rear are fitted and what exactly's required?
    Many Thanks
    AndymacA4's Avatar
    Oct 2008
    154
    The powerflex bushes need to be fitted using same technique as any bush, first get the old one out and the part that needs the new bush in on a bench. Clean up the part and then use a big vice with a suitable drift to ease the powerflex bush into the hole. This needs to be done very carefully as it needs to go in square. A bit of washing up liquid as lube works well.
