Chris NottMonster Motorsport
Results 1 to 9 of 9
    Jun 2008
    Epsom, Surrey
    233
    Coolant - G12 only or with water???
    what do you all reccomend, straight G12 coolant or G12 mixed with say 50% water?
    I am wondering this as my Fan seems to come on alot these days and am wondering if i would get better cooling if i include water.
    g60jet's Avatar
    May 2008
    UK
    147
    Given the fact you cant buy G12 anymore niether, you should be buying G12 plus (G12+).
    On the Bottle there will be clear instructions for the Mixture ratio depending on the climate.
    G12+ shouldn't be used neat even in the most extreme conditions IIRC
    |Present: 2005 B7 Audi A4 Avant 2.0T FSI Quattro S-Line|DIS|Phatbox|Aircon'd Glove Box|Ambiant Light Pack|
    |Gf's Motor: 2003 8L Audi A3 18.T Sport | Standard |
    |Previously: SEAT LEON FR TDI|German Spec Corrado G60 JET LHD|Mk2 Golf Cab|Mk2 Fiesta 1.4s|
    Jun 2008
    Epsom, Surrey
    233
    Yeah i meant G12 Plus
    Yeah i did see the mixing ratios but in the end which i can't remember why now i decided to follow my mates guidance and just use straight G12+.
    I wonder, what way would you recommend, drain all coolant and start again with proper mix raitio or just empty expanision tank and fill that with water??
    BTW normall tap water or distilled?
    Sorry about all the questions, i am used to premixed antifreeze with old car
    Quote Originally Posted by g60jet View Post
    g60jet's Avatar
    May 2008
    UK
    147
    Depending on the Age of the car really
    if its less than 10 years old and the coolant is a good clean pink, drop the coolant out and refill in the correct ratio.
    if older then i'd flush the system the distilled water (wont cause rust to start etc). Remember when draining / filling the system to check you are draining from the lowest part you the system (sometimes cars have a drain plug) and refill from the expansion tank or top rad hose, depending on the recommended method for the engine. Most cars its the expansion tank nowadays.
    Jun 2007
    6
    you can buy testers (refractometers) sorry spelling isn't my strong point, this will give you a reading of you coolant strength
    M7R
    Type Approval Engineer,
    Sep 2008
    Chilwell, Notts
    212
    as said bellow, G12+ (now out of date..its G12++) should be used 50/50 for protection down to -32iirc, or 2-3 parts g12 to water for down to -25deg.
    drain the full lot, there should be a drain plug on the bottom hose next to the radiator, then quick flush, and then refill with distilled water and G12++ pre-mixed 50/50 through the header tank while squashing the pipes and with the in car heaters on full hot.
    start the car, allow to get to temp and leave the cap off to allow any air locks to escape.
    83 GTi - road legal track weapon - now running 2.0l 16v super charged, = FAST!
    Daily hack: Audi A4 Avant S Line 2.0TDI Motech map to 175bhp, Milltek twin exit system, 1/2 leather, DIS, Fan washer jets, B8 rear aero wiper, FK headlight,
    Jun 2008
    Epsom, Surrey
    233
    Hi,
    yeah i still have some G12+ left so will just use that.
    50/50 sounds cool - according to the bottle this is 1 bottle of G12 and 1 bottle of water - this sound about right?
    Yeah i think it's best if i just drain the lot - i will see if i can see this drain plug.
    ALSO WHERE CAN I GET DISTILLED WATER FROM?
    Thanks very much for your help
    Quote Originally Posted by M7R View Post
    M7R
    Sep 2008
    Chilwell, Notts
    212
    you can get distilled water from most car auto spares places in bigger bottles, or smaller ones from tescos etc. as its used for ironing to stop scale build up
    Jun 2008
    Epsom, Surrey
    233
    All done:
    drained all coolant using drain off plug on rad and then filled with 1x G12+ and about a litre of non ironised water i got from Halfords.
    The temp sits much lower and cools must quicker when driving along.
