EM TuningMonster Motorsport
Thread: alarm siren
    Jul 2008
    30
    alarm siren
    after never hearing the alarm but hearing the ocasional beep beep noises and searching the forums came to find out that the siren batterys are knackered and leaked acid all over the circuit board now will the car still be fine with the siren disconnected until a replacement can be bought or could the imobiliser kick in?? tested the central locking and starting the car and everything works the same as before but just dont want to get stranded away from home because the siren that does not work is not connected
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    it will be okay with it disconnected, just order a new one from Audi as soon as you can.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Aug 2008
    40
    Better remove the battery that leaked. Its ok to disconnect it you will not have problems with it.
    ________________
    Good Find: Cargo Liners
    Jul 2008
    30
    all sorted know replacement unit sourced
