Monster MotorsportEM Tuning
    stevey_boy's Avatar
    May 2008
    35
    Bulb blown warning light
    on my 02 A4 the bulb blown warning light doesnt come up on the dash when a bulb has gone, is this easly fixed??
    stevey_boy's Avatar
    May 2008
    35
    Anyone??
    Milton Keynes UK
    248
    What bulb had blown?
    I know that my old 1998 A4 only flashes the Glow Plug light to indicate a brake light buld has blown. It does not detect any other bulbs. I don't have DIS.
    Maybe someone with DIS can post what bulbs the system monitors.
    Jun 2003
    World of my own
    9,813
    My DIS tells me bulbs are blown when they're not.
    It should tell you about all external bulbs, brake lights, headlights & side lights, also which side.
    Alex Turner
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,148
    You need to check that cold diagnosis is enabled with vag.com
    8P2 S3
