Chris NottMonster Motorsport
Results 1 to 7 of 7
    ALPINE's Avatar
    Yes its diesel, now cry u lost
    Apr 2008
    S/E LONDON / KENT
    3,086
    how to clear the service light
    ..........without vagcom. i have the IN2 service light on and the car has been serviced. its a 96 A4 turbo sport.
    cheers
    Now to many mods to list! Lots of power, torque and Leather!
    Jonesy's Avatar
    Jun 2004
    Kent
    570
    On my car an audi s3 8l, you have to hold down the milage trip reset button. Turn on ignition and press the left button which does all the sensor checks.
    2001 Audi S3 - Facelift - Revo remap - Forge 007p DV - BMC Panel Filter- Type R Ariel - Aero wipers - n75j valve.
    Darkshrimp's Avatar
    Mar 2007
    Perth, WA, Australia
    44
    hey, thanks that worked :d but the beeping is still there, but it doesn't say Service! anymore.. how do i turn off the beep as well?
    AndymacA4's Avatar
    Oct 2008
    154
    There shouldn't be a beep if the mileage for next service has been reset. When you press the spanner button, you should get a mileage till next service. That should have reset to 10,000 miles or 365 days. If it hasn't the reset by button pressing didn't work.
    You might need to take it to a garage with a code reader and reset tool. Look up Bosch service garages near you, they will be a lot cheaper than Audi and have all the necessary computer systems to check your problem
    Darkshrimp's Avatar
    Mar 2007
    44
    well my a3 doesn't have the display, it only displays service when it reckons it needs a service or normally it will simply display OK!
    haha
    and now it doesn't display service anymore, so i reckon the buttons worked but the beep still there
    audi80sport's Avatar
    is it home time yet?
    Sep 2007
    kettering
    116
    or take it quick fit and pull someone to the side and say ten quid to you if you reset it with the hand held device they have...
    Jun 2009
    i have a b5 a4 1.8t qaut
    how do i reset the light too.
    ive done the oil and filters just need to clear the service light
