    Mar 2007
    22
    10k boost 1.8T Where to Spray?
    Hi,
    The can of 10k boost instructs you to spray as close to the turbo as possible whilst running the engine.
    Can anybody suggest a good place to gain access?
    AndymacA4's Avatar
    Oct 2008
    154
    If after the turbo, there is a little blanked off cover on the intake manifold at the back, that would allow you to spray the stuff in, if before turbo, then probably best to take out the airfilter and spray it into the intake pipework from there. What part do you want to clean with it?
