EM TuningAH Fabrications
    Mar 2004
    Leicester UK
    133
    Steering rack (loss of fluid)
    HI all, I have a 97 tdi 110 and have a leak on the drivers side of the steering rack, the engine is out at the moment so the rack is easily accessible. I have a split in the rack gaiter and a load of fluid is coming out but shouldn't there be a seal to stop the fluid getting to the gaiter, as i thought the gaiters job was to keep the dirt out?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,511
    The gaiters job is to keep dirt out, the seals have gone in the rack. When my friends went like that we changed the rack. Its not hard but fiddly with the engine in, so if its out, now is the time
    evilscotsman's Avatar
    Space Cowboy
    May 2008
    Fife, Scotland
    1,345
    its near impossible wi the 1.8 20v engine in the A4, and I was told it was the only job the garage had ever seen come up in red on the autodata repair quote system!
    I drove the car (B5) until I got fed up topping it up just to get 5 miles, then the steering pump burst a gut at 172000 miles (!) scrapped it and had an Alfa for a while (crap build quality - a fiat wi knobs on and a fast engine.) now back to a B6. Luvvin it.
    Better to do it now while you have the easier option, I noticed that my B6 was slightly low on fluid, got the right stuff and topped it up, (proper VAG or MUST be mineral based audi suitable. All other fluids will feck the seals even quicker and it will piss out, believe me.) no leaks and no problems since, still full after 3000 miles. I reckon they use a tiny bit of PS fluid all the time and over a few years it goes down and down, by the time you notice the howling starting in the pump, the damage is done as the system dries out slowly over many miles and the seals shrink and crack.
    Hope you get it sorted out ok mate.
    B4 TDI - old skool project / daily driver...if it ain't broke, it's probably an Audi...
