Volks AutosEM Tuning
Thread: Water problem
    May 2008
    Middleton, Manchester
    43
    Water problem
    hello again!
    within the 3 weeks i have had my 1998 A3 i have had to top up the coolant water level twice.
    possible leak? where are these likely to leak from? is a it a quick fix?
    all help kinndly received thanks guys
    Gee
    Mcblow's Avatar
    Jun 2008
    82
    having similar problems mate...not sure what it is...typed it in google to see what happened...saw lots of people reporting the same problem...but no one giving an answer as to what the problem is..so if you have found out can you let me know..i'm thinking sumat to do with waterpump!!cheers sean
    Current cars...
    MK2 Golf 16v gti
    A3 8p 2.0fsi...
    Looking for 2002/3 Red S3 below 80k and £6k
    www.dubsuffolk.com
    26,716
    Dont laugh at this but it might help you locate the leak, hear me out.
    I assume there are no wet patches left over night on the ground under the engine area, if not then I would stick a towel, large sheet, blanket or bit of cardboard under the car, start the car & leave it to be build up pressure in the system for anything upto an hour to give it time & see if it drips anything down onto the material below then this would give you a general idea of where the leak is as it must be going downwards obviously, then you can start tracing threw.
    If there arent any overnight then sounds like a tiny pressure leak as it would seem to only lose water when the system is running & pressure is maybe making the minute split in a pipe that usually when not in use would look like a completely sealed pipe, release droplets of water cause twice in 3 weeks it would say its losing water @ a very very slow rate.
    Have you checked pipes around the areas you can, squeeze them to see if it releases any water from anywhere, even the smallest of split pipe would be causing your problem, try this when engine is running so you are adding little pressure to the pipes, of course with care.
    Have you had the cambelt done, when its done they should also replace the water pump always, as its a 98 the pipes are fairly old so might have a split & sounds very likely TBH.
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    Check for a residue caused from the coolant. Coolant will form into a crystalline like substance... Just trace along all water jackets and piping, including the radiator/heater matrix. Even a very slight leak will leave tell tale signs like this. You could also have the cooling system pressure tested to make sure the cap on the coolant bottle is not faulty. This would also show up any obvious leaks. On older cars a head gasket could also be to blame, though you would more than likely see water in the oil if this was the case.
    Bird watching freaks of the world unite at:
    http://www.simplybirding.com
    Even the RSPB would be afraid...
    enda1's Avatar
    Jan 2006
    Ireland
    439
    Quote Originally Posted by nigelhobden View Post
    Im had this on my 80 and there was a pin hole leak that sprayed the coolant straight onto the block where it evaporated instantly. took me a few weeks to find
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
    807
    you can get it pressure tested at a good garage, they will find any leaks, although obviously it will cost
