Volks AutosBadger5
    London
    160
    Angry rocker cover keeps leaking
    why does my rocker cover keep leaking oil??
    i have changed the gasket twice..
    parts were from euro car parts
    any one help...
    Jul 2006
    19
    hi s3syd,
    i have read somewhere that the fuel injection pump develops a problem and pressurises the engine, thus putting the rocker cover under extreme pressure and therefore leaks. check out your sump oil for deisel contamination. i hope i have not worried you too much, but it needs checking out. good luck, barney.
    Jul 2006
    19
    hi s3syd,
    i have read somewhere that the fuel injection pump develops a problem and pressurises the engine, thus putting the rocker cover under extreme pressure and therefore leaks. check out your sump oil for deisel contamination. i hope i have not worried you too much, but it needs checking out. good luck, barney.so sorry you drive a petrol audi in that case i don't know.
    Jul 2006
    19
    hi s3syd,
    on second thoughts your crankcase breather may be partially blocked thus pressurising the sump in turn pressurising the rocker cover making it leak.
    hope that helps.good luck, barney.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,810
    where does it leak?
    London
    160
    oil leak
    as you look at the engine on the right hand side by the back
