hi s3syd,
i have read somewhere that the fuel injection pump develops a problem and pressurises the engine, thus putting the rocker cover under extreme pressure and therefore leaks. check out your sump oil for deisel contamination. i hope i have not worried you too much, but it needs checking out. good luck, barney.
