I have a 2007 Audi A4 AVANT SLINE SE 170BHP. Does anyone know how to turn off the security central locking. The only way I can get all the doors open from the remote is to press open 2 times. I want to open all the doors with just one press. thanks
Sounds like you have "one touch" opening setup.
The 1st press unlocks the drivers door, the 2nd press all the doors.
The only way to do this (I think) is to goto a dealers, or get someone with VAGCOM to modify it.
Was A3 1.8Ts
Now S3
You can get this done if you know someone that has access to VAGCOM, if you get them to plug it in, they should be able to sort if out for you in a few seconds....
Hope that helps, you could try going to Audi and see if a friendly person on site can do it for you, but i think they will charge you for it.
I'm not sure about A4 but in my 09 3 this can be changed in the set up menu, access from button under right hand stalk.
