Chris NottAH Fabrications
    Mar 2008
    HELP!!!!!!!!! possesed A8
    Help, I have an A8L BFM engine code, that wont start, the ignition switch seems to have gone on strike!! when i insert the key in the switch the steering lock usually releases but now there's nothing, when i try and use the start button it works some times and some times it says 'key not identifeid' when im holding the key inside the car!!!! has any body had this experience before??? Also this problem started with the battery being changed, PLEASE HELP
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    You probably need to take the car to Audi to have the key reprogrammed. Sounds like something is out of sync after the battery change?
    Bird watching freaks of the world unite at:
    http://www.simplybirding.com
    Even the RSPB would be afraid...
