AH FabricationsVolks Autos
Results 1 to 8 of 8
    cheekeemonkey's Avatar
    Dec 2007
    125
    Axle Stand Positions on an A4 (B6 Avant)
    Guys
    sorry for the dumb/newbie question....
    I am wanting to remove my alloys (1 by 1) to clean the arches and also clean/protect the alloys
    I am not keen on leaving the car jacked up on the OEM wheel change jack so would like to place the car on an axle stand.
    Here's the dumb questions....
    Where should the axle stand connect with the car at the front and the back?
    I presume it's dead straight forward but never used them before so don't want to find I bend or break somehting by putting it in the wrong place!!!
    PS Any photos/links would be really useful
    Thanks as always
    CM
    2003 A4 Avant 1.9TDi Quattro Sport
    Dec 2007
    125
    BTTT!!!
    C'mon guys - help me out - pleeeez
    Feb 2008
    7
    Just done a search on the net (as I am sure you have!!) and drawn a blank also. Have you tried ringing Audi up?
    SteveTDCi's Avatar
    Nov 2005
    Lincs
    1,384
    I'd be interested to find this out but for the A3, i've looked and mine is covered with plastic, I think it maybe a case of removing them and using the chassis rails, or you might be able to support the car at the same point as the jacking positions.
    Gone A3 TDi S Line DSG Bluefined
    Now Seat Leon Cupra about to be Bluefined
    macca's Avatar
    Sep 2006
    Sussex.
    525
    you can either put them on the reinforced bit that the OEM stand goes on or at the front put them under the jack points that protude doen from body furthur underneath behind wheel arch, they look like the lowest point on the car at the front.
    at the rear i can't remember off the top of my head, i think i use where the rear trailing arms join the body mount on my 2wd, can't remember.
    1998 A4 1.8T Sport - For Saturdays
    2003 VW Golf MKIV R32 - For Sundays
    2000 Peugeot 406 HDi - For when it's raining
    1996 Kawasaki ZX7R - For when I'm late for work!
    Mods- Forge Dump Valve, The Engine Shop Power Plus based Engine (Low Comp. Forged pistons, Arrow H-Section Rods, Newman fast road cams, polished & ported head), 19" wheels, B&M Short Shifter, Greddy Turbo Timer, RS4 Grill, Weitec GTN coilovers, HKS modified air filter, Autobahn88 FMIC, ChippedUK custom map. Some Turbo mods ongoing.
    Dec 2007
    125
    cheers - I'll take a look at the weekend
    CM
    Geordie
    Dec 2006
    Lancashire
    34
    If you use an independent garage for your MOT (if car is over 3 years old) he should be able to tell you where to put the axle stands. He might even put the car on the hoist and show you if you are on good terms! I'm going to ask my friendly garage the same question for my A3 sportback.
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    if you garage has access to autodata then he can just print off the digram of where the points are
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
