Monster MotorsportChris Nott
Results 1 to 9 of 9
    Feb 2008
    7
    A4 B7 (2005) OEM Navi Antenna Position?
    Hi
    Anyone have any idea where the OEM Navigation Antenna is located on an A4? I'm doing another RNS-E retrofit and always like to get the antenna in about the same location as the OEM one goes... done loads of Cabriolets (the antenna goes in the bootlid for them) but never a hard top.
    Any thoughts?
    Jan 2007
    Hampshire
    1,155
    In the sharksfin on the roof if it has telephone prep as well or like mine which doesnt have factory phone prep then it's built into the rear screen.
    A6 3.0 TDI.
    Feb 2008
    7
    cool... thanks for the speedy response.
    I have no phone prep or sharkfin so I reckon I'll stuff the nav antenna above the rear seat reading light. If the reception is rubbish it'll have to go by the centre brake light I guess.
    Jan 2007
    Hampshire
    1,155
    Quote Originally Posted by gatsoman
    Unless your fitting a sharksfin? The 'hockey puck' antenna will have poor reception as it doesnt have a clear view of the sky.
    Thats a lot of effort to route the cable all the way back there. Why not drop the glove-box and stick it to the underneath of the dashboard?
    Thats what I did when I fitted one for a friend - Always gets 7 or 8 satellites without fail. Only takes 10 minutes to fit it up there. Sky view is perfect as it looks directly upwards through the front screen.
    A6 3.0 TDI.
    Feb 2008
    7
    Thats a good point - I guess there is no value in me sticking it where it should go as its not an Audi OEM antenna anyway.
    Glovebox is coming out anyway making way for the CD Changer one so I will gluegun the antenna to the bottom of the dash.... easy!!!
    Jan 2007
    Hampshire
    1,155
    Fitting the non-OEM antenna under the roof will give terrible GPS reception. Much easier above the glovebox. FWIW I used some sticky backed velcro pads as I was a little apprehensive of a reaction with the dashboard material if I used the tube of superglue I had handy
    A6 3.0 TDI.
    hud at ye bam
    Jan 2006
    Aberdeenshire
    2,231
    Quote Originally Posted by Issac Hunt
    Only the Avants have the sharkfin, the saloons have the antenna up behind the rear reading light.
    [/sarcasm]
    Jan 2007
    Hampshire
    1,155
    The saloon I saw must've been retro-fitted then. What a pain in the arse job, no way would I be drilling holes in the roof.
    A6 3.0 TDI.
    Feb 2008
    7
    The thing is surely its metal up behind the rear reading light? How does the aerial get any reception? Or is it in trim by the rear window?
    I'm sure I am going to go for the behind the dash option, but interested all the same..!
