Chris NottBadger5
    Sep 2003
    medway,kent uk
    103
    vehicle data sticker
    just wondering if anyone knows where i can find what all those 3 digit codes mean on the sticker with regards paint/ optional equipment.
    cheers
    stevie
    Jan 2007
    Hampshire
    1,155
    A6 3.0 TDI.
    Carpy25's Avatar
    Oct 2007
    272
    check here it works for vw's
    http://igorweb.org/equidec/
    Rob
    beat me too it
    heres mine 2001 1.8 se
    E0A = no special edition
    7A2 = CD changer
    4UF = drivers and front passenger airbag with front passenger airbag deactivation
    6XD = outer rear view mirrors: powered, heated
    5SJ = outer left rear view mirror: convex
    6TS = outer right rear view mirror: non-spherical, large viewing field
    1KK = disc brakes, rear
    J1L = battery 280 A (60 Ah)
    1LS = front disc brakes with integrated adapter
    1AT = electronic stabilization program (ESP)
    3FA = without roof insert (standard roof)
    1JJ = rear shock absorption, basic design
    G02 = front shock absorption, standard 2
    5TC = without decorative inserts
    7X0 = without park distance control
    4R1 = power windows
    F0A = no special purpose vehicle, standard equipment
    0L2 = electric throttle actuation
    8GL = alternator 120A
    0G4 = cable gearshift
    0YZ = without determination of weight categoryfor rear axle
    L05 = suspension range 05
    T0V = components for, base engine, unit 06A.A
    3NC = rear seat bench/backrest, split folding
    8JK = ellipsoidal headlight for driving on the left
    U1B = instrument insert with mph speedometer, clock, tachometer and trip odometer
    X2B = national sales program Great Britain
    1N6 = power steering
    1MR = leather steering wheel
    8Q1 = headlight-range adjustment
    9Q0 = without multi-function indicator/on-board computer
    8Z5 = engine cooling system, type 1
    ME9 = 4-cylinder gasoline engine 1.8 L/92 kW 20V with multi-point injection, base engine is T0V/T5Z/T64/T6W
    7Q0 = without navigation device
    CE6 = cast alloy wheels 6J x 15 offset 38 8L0 601 25 N"
    4X1 = side airbag front
    6R2 = leather gearshift boot
    3L3 = manual height adjustment for front seats
    4K4 = radio remote controlled central locking operated from inside and separate trunk release
    5D1 = carrier frequency 433.92 MHz
    1SA = without additional engine guard
    0GE = emissions concept EU 3
    Q1A = standard front seats
    QG1 = service interval prolongation
    4GP = windshield tinted with sun band and viewing window for vehicle identification number
    seems about right to me
    Sep 2003
    medway,kent uk
    103
    thanks boys, heres mine
    LY5X/LY5XN1H/MBE0A = code not found :-(
    0GZ = emissions concept EU 3
    1KD = disc brakes, rear
    J1D = battery 380 A (72 Ah)
    1LB = disc brakes, front
    1BE = sports suspension/shock absorption
    5TM = decorative aluminum inserts "check gray"
    8GU = alternator 140A
    0G1 = gearshift lever
    0YD = weight category rear axle weight range 4
    0JG = weight category front axle weight range 7
    T9J = components for, base engine, unit 038.K
    3NZ = rear seat bench unsplit, backrest split folding
    U1D = instrument panel with additional guages
    1N1 = power steering
    3HA = without leather parts scope
    9Q2 = multi-function indicator/on-board computer with check control
    D3E = 4-cylinder turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system, EU 3, base engine is T9J/TG0
    C1L = cast alloy wheels 7J x 16 five-arm style, offset 45
    7K0 = without tire pressure warning light
    VJ1 = reinforced bumpers
    3PF = electric height adjustment for both front seats
    4KC = side and rear windows tinted
    3Y0 = without roll-up sun screen
    stevie
