Volks AutosBadger5
Results 1 to 8 of 8
    Dec 2007
    14
    Won't idle when cold .
    OK , my 96 1.8 a4 , when dead cold , starts , but wont idle when cold , holding it about 1500 rpm it will die then just about 500rpm it will come back up to where I am holding it . A good blip on the throttle will clear it for a short while . But only after 1 or 2 mins of running time it will be fine , idles ok ( idles high at operating temp , 1200 rpm due to somebody putting a cable tie under the throtttle cable clip )but dosn't pulse .
    Now , I have had abit of a clean of the throttle body , got as much of the crap out with brake cleaner and a rag , but am tempted to get back in there and have another go and get the compressed air down a fewof the ports I can see . Wise idea ? Other than that am thinkin it can only be an electrical fault , dodgy cold start temp sensor or something . Not fully up to speed on audi engine managment stuff yet .
    Any help appreciated ,
    Cheers Cam
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    Sounds like the car is not going onto choke, probably a sensor gone faulty.
    Maybe post up in the VAG-COM forum to see if anyone in your area has it to run a diagnostic.
    I have it and I don't even own an audi any more!
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
    Dec 2007
    14
    Cheers , Yea , have posted on the vag.com forum asking for sombody in my area . Whats it worth if you want to sell it ?
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I wouldn't sell it to be honest, its worth its weight in gold, as soon as ross tech develop a BMW version of the software i'll be as happy as a dog with 2 dicks!
    They're about 270 quid to buy a geniune one.
    Chris
    See my images @
    Feb 2007
    It'll need a new ECU temp sender, it's a pretty common fault on the 1.8.
    Should be one of these
    Hope this helps
    Dec 2007
    14
    Cheers , have friday off , so will be goin somewhere to get this thing diagnosied ,think there could be a couple of other things checked , then off to where I work to hijack the host for the arvo , have an exhaust leak to weld up as well .
    Dec 2007
    14
    Well 10 Pts to SteveU , had my codes read , coolant sensor was one of the faults that came up , the others were faults that related to the coolant sensor . So one 15 sensor later and 5 mins to fit it , job sorted !
    Feb 2007
    Glad to be of service!!
