Chris NottJMB Retrofits
    S6 avant
    Oct 2006
    bewdley Worcestershire
    689
    alarm-tailgate problem!
    my alarm has started going off everytime i lock the car. when i lock it everything is fine then when it goes off the boot light is on and wont go out at all even after opening and shutting the boot. it eventually randomly goes out then the whole thing starts to happen again.
    im thinking bootlid door pin switch, but where the hell is it????? can anyone help please?
    2000 s6 avant, special order met, green, satnav, Bose, tv, solar roof, privacy glass, recaro silver nappa.
    S6 avant
    Oct 2006
    689
    fixed now. bad connection to boot catch switch.
    A3TDI
    Nov 2008
    Worcestershire
    116
    i have this exact problem and it has only just started today..i was about to start a new thread and then i came accross this..can you give me any information on how to locate this?? is it behind the black plastic cover inside the boot lid itself? what exactly did you do to fix the connection problem?? if anyone else reads this and knows the answer it would be much appreciated if you could shed some light on this, as you can imagine it is very urgent as im having to leave my car unlocked!!
    807
    I can tell you what happened with my A3, the light was not coming on much, not setting off the alarm but bugged me so i looked into it.
    There is a plug which goes into the rear lock(in the bootlid) which signals if its open or closed. This could be loose or bad contact... Or could be a faulty lock, on my A3 it is a closed unit so would have to be fully replaced but i seem to have fixed it with copius amounts of wd40 into the lock and connector to prevent rust mmessing up the connections..
    To get to this is easy, the tailgate plastic cover pulls off (there are some screws in the grab handle to undo first). I cant remember on the A6 if there are any more screws i havent done one in ages but they should be obvious.
    Once your in you should be able to see whats going on and test a few things out.
    FYI Also in my infinite wisdom i tried slamming it shut, but i didnt realise i pushed the mech it to the locked position before, this pushed the metal bar which it locks to down meaning my boot wouldnt shut, so had to spend a while stripping it down and fixing that bar to where its meant to be lol (that bar is slightly movable once loose.
