    Oct 2007
    12
    plzzzz need help blower fan
    when i turn on the switch of blower moter it doesnt work in 1,2,3,4 it only work in 5 and most of the time its stop when kick in dash it works but today all day it was not working i kicked and punch the dashbord still didnt work please can anyone tell me what it could be.
    Oct 2007
    12
    hello is there any smart person who can help me?:D
    scrupes's Avatar
    bloody great extension bodger
    Jul 2004
    at R88PERS beck and call AGAIN!!
    236
    Quote Originally Posted by audi-90qua
    sorry but it sounds like you've pulverised your dashboard hehe
    have you looked to see if the wire is still conected to the switch?
    if so the switch could be broken, some of the older type switches can be opened gently to enable you to clean the brass runners the switch runs along as you turn it, sounds complicated i know but it's quite easy to do with a little care and attention.
    good luck.
    Jun 2003
    World of my own
    9,813
    Most likely the motor brushes are worn out, putting it on 5 pulls enough current to get it working but anything lower doesn't. You either need to replace the motor or the brushes inside the motor - have a look on ebay
    foolish3uk's Avatar
    Aug 2004
    in middle of nowhere
    458
    i take it it is a audi 90???
    most probably the resistance pack in the air pipes, it has a massive cooling unit on one side that looks like bristles, on the a4 it is right next to the blower motor itself i think it has a blue or green plug on it, this fault will be either this which is the most common or as andy mac said the blower motor.
