EM TuningChris Nott
    Dec 2006
    Dead battery...need help!!
    Little help needed.
    What do you do if your audi a4 has sat there for a few weeks offroad,
    and the battery is so dead, it wont opperate your electric central locking??!!
    is the only option to smash a window??
    its an audi a4 1.8t p reg if that help.
    any help appreciated.
    cheers, steve
    Sep 2007
    Ellesmere Port
    160
    Call me stupid... but why can't you unlock drivers door with the key? i know it will be deadlocked inside but unless you have no drivers key hole....????
    Sep 2007
    Ellesmere Port
    160
    If you have no key unlocking then the only suggestion is to make up a lead with 2 small crockadial clips and put one to earth and then try and get other to your starter (there will be a thick cable going back to batt - connect to this) underneath, that will push enough power through cables to power up the central locking, should be able to remove your engine cover from underneath to do this.
    Oct 2007
    2,597
    Or, just bash in the off side rear lamp, I mean completely through. Then, remove the vacuum pipe from the central locking pump, and suck / blow till the buttons pop.
    If you've deleted all the key holes, then, I'd say you deserve to get locked out!
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    904
    surely there must be a boot lock as i've never seen a boot de-locked, just use the key in that, once the boot is open attach a set of jump leads or charger to the wires on the boot light to power up the system.
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
