Chris NottBadger5
Results 1 to 10 of 10
    Aug 2007
    Kent
    Exclamation Coolant warning light in A4
    Afternoon all
    Just bought a second hand (R reg 1998) A4 SE 2.4 v6 and drives like a dream so far.
    However, when I first start the car (after approx 1-2mins) the coolant warning indicator comes on (with beeping) in the main LED display.
    It usually stays on for 10 mins or so before clearing.
    Any clues as to why??
    Have I got a problem (still under warranty)
    Not technically minded so you may have to keep it simple
    petewon's Avatar
    Dec 2004
    Newcastle
    514
    Welcome. Stupid question but have you checked the coolant level? If its above the mark then I could only think its a faulty sensor.
    Pete
    _______________________
    8P A3 2.0 FSI Sport, Leather/Alcantara, Bose, Xenons.
    diesel-a4's Avatar
    Stoned As Fuk
    162
    will any kind of coolant do the job?
    also whats the best oil to stick in one a A4 1.9 TDi
    Oct 2006
    Manchester
    724
    Hi
    No you cannot mix the coolant
    You may have the G12 which is pink in colour
    If it is blue then it is G11
    Lilac is G12+
    GSF usually sell it , but you cannot mix pink and blue!!!!
    Sarah
    diesel-a4's Avatar
    Stoned As Fuk
    162
    thanks sarah, any idea about the engine oil?
    Oct 2006
    Manchester
    724
    What BHP one is it?
    All the PD engines need the PD oil you see
    Sarah
    diesel-a4's Avatar
    Stoned As Fuk
    162
    shes the 110bhp standard but with the chip shes now 163
    Oct 2006
    Manchester
    724
    Hi
    The 110 is not PD
    VW 505.00
    For all diesel engines prior to model year 2000 (August 1999)
    Viscosity rating: 0w-40, 5w-40 or 10w-40
    Hope that helps?
    diesel-a4's Avatar
    Stoned As Fuk
    162
    thanks Sarah, you a star
    Oct 2006
    Manchester
    724
    Your welcome
    Sarah
