EM TuningChris Nott
    Jun 2007
    East London
    50
    New head needed for my S3 - brand new, or second hand?
    The engine's out of my S3, and the bottom end is salvageable (had no compression in 3 or 4, v little in 1 & 2, there was loads of sh!te in the sump - metal & plastic (latter from the cambelt tensioner, which got destroyed)), thankfully....the head, however, is mince (8 valves bent).
    I've been quoted 1416 incl vat, for a brand new head (exchanged with mine), with new cams, plus 100 for head bolts & gaskets. I've also seen an apparently 18,000 mile head for 450.
    Now, there's lots of other work being done on the car to get it running again (timing belt & kit, turbo re-build, new clutch, oil pump, re-map, wheel re-furb....phew!), so, do I save a grand, or is buying second hand heads just too dodgy?
    Appreciate any advice, in a bit of a quandry...
    Thanks,
    greggers
    Complete Pleb
    Dec 2006
    East Grinstead
    89
    Depends where you've seen the second-hand head. If it's from a reputable dealer then a head with 18,000 miles shouldn't be a problem and you can always inspect the wear on it. Whereas, if you saw it on eBay from a bloke with 3 feedback asking for cash on delivery ................. hmmm.
    Personally I'd be inclined to check out the second-hand one and see what state it's in, but I should think it'd be in fairly good nick.
    Jun 2007
    East London
    50
    Sounds about right Chris - it's the kind of thing you want to know you're buying off of someone sound, cos of the amount of things that could be wrong with it.
    Found myself a complete, newly built engine last week, hoping that it's a good un!
    Cheers,
    greg
