The engine's out of my S3, and the bottom end is salvageable (had no compression in 3 or 4, v little in 1 & 2, there was loads of sh!te in the sump - metal & plastic (latter from the cambelt tensioner, which got destroyed)), thankfully....the head, however, is mince (8 valves bent).
I've been quoted £1416 incl vat, for a brand new head (exchanged with mine), with new cams, plus £100 for head bolts & gaskets. I've also seen an apparently 18,000 mile head for £450.
Now, there's lots of other work being done on the car to get it running again (timing belt & kit, turbo re-build, new clutch, oil pump, re-map, wheel re-furb....phew!), so, do I save a grand, or is buying second hand heads just too dodgy?
Appreciate any advice, in a bit of a quandry...
Thanks,
greggers
Thanks,
greggers
