EM TuningAH Fabrications
    Jul 2007
    Audi Torque Values 2.7T (A6 S4)
    I need the torque values for the bolts on a 2.7T engine (A6 S4) timing belt change job. ie: waterpump bolts, crank pulley bolts, cam, etc.....Thanks...
    enda1's Avatar
    Jan 2006
    Ireland
    439
    These values are from elsawin. If you send me a pm with an email address then I can send you the procedure, I need the engine code to make sure i send you the right info
    Tightening torque
    Toothed belt sprocket on camshaft
    55 Nm
    Idler wheel
    45 Nm
    Toothed belt tensioner
    20 Nm
    Pulley on crankshaft
    20 Nm
    10 Nm
    Central crankshaft bolt 1)
    200 Nm + 180°2)
    1) The central bolt should be replaced.
    2) 2 times 90°further turning is permitted.
    Water pump boltTightening torque: 10 Nm
    Enda1
    96 S6 2.3T
    99 A6 1.8T SE
    93 80 2.0 (gone)
    93 Kawasaki ZZR600
